Ballon Stack
Is there a way to stack item callouts and note flags in this way?
Re: Ballon Stack
while placing them you can touch an existing item and then yes, you can place like this.
IF the item is already placed, it's quite a chore, as you need to turn on the leader, attach, then re-hide the leader...
but in general yes you should be able to do this during the original placement step by 1st touching another item then it will "lock to it"
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Re: Ballon Stack
My issue is trying to get the flagged notes to running horizontal to balloon 8. The keep wanting to auto locate to the bottom of the last balloon (63)
Re: Ballon Stack
What about the "Annotaion Alignment Shape" option and lock your balloons to that?
JGUN
