Batch program - creating PDFs only process 1st sheet of multi sheet drawing
I use the batch program frequently to send dwg files to vendors.  Converting to dwg works well with multi sheet drawings.
Today I tried converting to PDF but it only processes the first sheet.  Am I missing a setting?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
3 REPLIES 3
Re: Batch program - creating PDFs only process 1st sheet of multi sheet drawing
@kjoiner  Assuming the batch does not set any of the PDF options so you probably need to set them before by doing a manual save to PDF and set the Options to save all pages instead of the active page/sheet.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
From the GTAC Solution Center articles database...
http://solutions.industrysoftware.automation.siemens.com/view.php?si=002-8007194
How to export multiple draft sheets to pdf using the batch.exe program?
Symptom
How do you export multiple draft sheets to pdf using the batch.exe program?
Hardware/Software Configuration
Platform: INTEL
OS: WINDOW
OS Version: 764
Product: SOLID_EDGE
Application: DRAFT
Version: V110MP10
Function: FILE
Solution
You will have to set the option in save as pdf to export multiple draft sheets; the batch.exe looks at the current settings used in the Save As command.
That worked!  Thank you so much for the help!
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
