Batch save as flat (dxf)
Is there a method within Solid Edge to do a batch "save as flat" in the sheetmetal environment ?
Kind regards,
Jan Bos
Betreff: Batch save as flat (dxf)
Esteemed Contributor
Hi @Jan_Bos
this was an issue a time ago.
And I only can offer the same solution as at that time.
See link:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Batch-processing-Flat-patterns-in-D...
Wolfgang
Many thanks Wolfgang....
Hi Wolfgang,
Just used the macro and it did the job, many thanks....
The only "problem" is that it can not see those modern folders like dropbox, one drive, google drive..
I'm doing this project in dropbox in order to have the maximum speed (all files from my ssd) and do'nt have to worry about backup... and can access it from home.
Many thanks.
Jan Bos
Emmen, The Netherlands
User since V3.5  beta testing ST10
Hi @Jan_Bos
regarding Cloud Drives, is it so that e.g. GoogleDrive will be linked to c:\Users\Username\GoogleDrive?
Using this path should let You access those files?
Wolfgang
