[Beginer] loft open sketch
Is it possible to make a "loft" with non-closed sketch ?
I would like to make the hull of a boat.
Thanks for you help,
Sure. The tool for this is "BlueSurf" found on the Surfac...
Community Manager
Sure. The tool for this is "BlueSurf" found on the Surface Tab.  A loft is by definition defined with cross sections only in the U direction. BlueSurf lets you do that but also much more. This is loft on steriods and let's you do about 10X more things.
Dan Staples
