Bend options
You guys helped me figure out how to step bend a sheet metal part by using a lofted flange and using the triangulation bending option, I really appreciate that.
I have a sheet metal part that has a radius on it that will be bent using a combination of a step bender (or whatever its called) and a brake press.  For standard bends, we will use the brake, but for the radius we will use the step bender.
It seems I have to go either or on the bend option and am left here scratching my head on best way to portray this on a drawing to production.
part is attached
Re: Bend options
Just make the large radius using the lofted flange and then add the other bends to it using the Contour Flange command.  Then you can have both bend types.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Betreff: Bend options
Hi @lifofadrafter
to get what You want, I found following way:
  • Create the Lofted Flange, but for the big radius only
  • Creat Flanges (You only can use the option "Bend Radius Outside" for this to get the other flanges
See video
(view in My Videos)
Wolfgang
Re: Bend options
Hi @KennyG
just seen that You were faster a couple of minutes.
But "Contour Flange" will not take the long edges of the "Lofted Flange"
This is the reason why I have used the standrd Flange feature
PS.: to get the correct bend angle in above video, I have used construction lines in the first sketch to get the right angle for the variable table, to use it in the formula for the bend angle
Wolfgang
Re: Bend options
HI @lifofadrafter
just was in the process of answering Your intermediate post which was deleted suddenly
So see attached video where I show the complete process of creating this shape
(view in My Videos)
Wolfgang
Re: Bend options
@hawcad  I had no problem using Contour Flange...
(view in My Videos)
Re: Bend options
freaking genious I tell you
Re: Bend options
Hi @KennyG
great job.
The problem I had occured due to the fact, that I had not created the sketches before and used them as You did, but tried to do it "on the fly" with profil normal to curve, but SE will not accept the edge of the Lofted Flange as base for a new Contour Profil
But of course, creating everything before will help a lot here.
On the other hand, difference of using Flange only afterwards to contour flange is not that big issue.
Finally theonly which counts is, wether or not YOu have done Your job, isn't it?
Wolfgang
Re: Bend options
Now am I able to pull lofted flange bends into a bend table?
