Bend out into SE ST9
Ladies and Gents,
I have imported, bended leg (please see attachment).
  1. I want to bend out as fast as possible. Could you give me a piece of advice?
  2. Could you give me good tutorial about bending?
Thanks.
I did, I understand.
5 REPLIES 5
Re: Bend out into SE ST9
I have found Tools->Expand <Prefabrication> (sorry for translation but I have national language in SE).
Is there another ways to do this?
No sheetmetal expert but here's a video of what I know about flattening:
@Tushar: I have discovered this way. Thank you for video.
For some reason it seem that the thicknes of that model is not uniform.
I have copied the top surface, removed the original body, applied a thicknes of 0.38 mm and then been able to use the "transform in synchronous sheetmetal" tool sucessfully.
Here a video:
@Fiorini: Thank you for checking. Grazie mille
