Re: Best practice to model a Flex-rigid PCB
Tushar,
The last reply that I wrote is the full explanation and example file of how the Flex-rigid PCB should be done. therefore I marked it as the 'Accepted Solution'
All the stuff that Wolfgang wrote was the base to my explanation (so I Kudos them).
Zohar
Thanks Zohar.
I appreciate.
~Tushar
