Best way to handle overlapping flanges
Best way to handle these overlapping flanges.  Files is also attached
Re: Best way to handle overlapping flanges
A contour flange along the 3 edges would automatically miter those corners.
Edit: Uh, maybe not
Bruce Shand
Hi there @lifofadrafter,
Normally I would just use a contour flange to get those corners mitered automatically.....but in this case, you could just modify the side angle of the flanges, retrospectively.
@SeanCresswell, Dang, just finished a video showing that.
Bruce Shand
...and here is a sheetmetal part, using the contour flange approach.
@bshand & @hawcad......All the great minds think alike!  Robot Very Happy
Betreff: Best way to handle overlapping flanges
Hi @lifofadrafter
I also would follow the hint from @bshand to use the contour flange, and Yes @bshand it works here without any problem and as usual.
See modified example in attachment
Wolfgang
Hi @lifofadrafter
Hi @SeanCresswell
Hi @bshand
and another approach also is the ConvertToSheetmetal method from full part model to sheet model
Wolfgang
Hi @SeanCresswell
You were ahead by 50 seconds!
Congratulation!
Wolfgang
You're half right.
Bruce Shand
@hawcad,
All in the name of our great "community"........love your work buddy!
