Best way to measure a diameter in a specific case
Hello all
I'm trying to understand how is the best way to measure a diameter, in case the sketch was made from a square, and knowing that after I'll make a revolution of this created sketch.
Should I measure directly with the "Smart Dimension"? Or should I measure with the "Symmetric Diameter" and let the command "Smart Dimension - Enable Prefix" enabled?
Thanks!
Re: Best way to measure a diameter in a specific case
Hi there,
Are you working in Synchronous or Ordered mode?
I think Sync works best in this case,....just make your revolve, then add a PMI "smart dimension" to the resulting diameter, also, with a Sync revolve you'll see a "live section" apear automatically....very handy for adding more dimensions to control the shapes, especially more complex ones.
Solid Edge ST10 [MP7] Classic [x2 seats]
Hello, I'm very thankful. But, in fact, I'm working in the ordered mode.
So, is this also work by using the ordered mode? If not, how could I measure that diameter?
Joao
Hello João,
Well in ordered mode, dimension the sketch as you said, using the symetric diameter.
OK, thanks!
