Blank body Command failed
Hi everyone,
can somebody help?
my solid edge blank body command now is always failed although i m trying with very simple thin-wallled design. its always failedwith the poped up message "the mesh could not be generated. adjusting the accuracy may help give a succesful result". which are previously no problem even with a bit complex contour.
please help
Re: Blank body Command failed
Could you share your model?
BR,
Imics
