BlockViews use
Hi Everyone,
I have started to code on SolidEdge using C++. The goal I want to achieve is to have promatically the following representation :
Where you have a block that contain few block view, each block view contains a drawing.
Each drawing are from DWG so I import them by using AddBlockByFile function, as a result I am getting the following
How can I use the inserted blocks in order to add them to my master_block? I am a bit lost with the view concept.
Here is what I get :
7 REPLIES 7
Betreff: BlockViews use
HI @Trace_Parts
maybe You will get better and faster response when asking this in the Programmers Forum rather than here.
Wolfgang
https://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/bd-p/SEDeveloperForum
http://Grundey.blogspot.com
@hawcad, Off topic but something I've been curious about for a while. Often after you've responded to a post the post description gets prefixed with "Betreff:" from then on. What is that?
Bruce Shand
and I don't see a Me Too button in your post @bshand Robot Frustrated
HI @bshand
I never recognized that but You are absolutely rigth.
This seems to come from answering apost here, that in the subject line automatically the German verb for Subject = "Betreff:" is written.
I never have observed on that.
I will take care in the future to delete those automatial addon.
Sorry for this inconvenience
Wolfgang
Hi @Tushar
Yes this is right too.
But I think a "Me Too" button only will be available for the beginning post, isn't it?
Wolfgang
@hawcad, It's not of any particular concern. I just always thought it curious. And I learned a new German word!
Bruce Shand
