Bolt hole circle
Not applicable
Help needed.
I am unable to work out how the bolt hole circle works.No matter what I do I have
yet to create one.
Can anyone tell me how to make this command work?
Re: Bolt hole circle
Not applicable
It annotates a circular pattern of bolt holes, so the circular pattern of bolt holes has to exist first. Once it does, selec the command, specify the appropriate circle option, and then position the circle so that it passes through the centerpoints of the holes. It will then place the circle and put centermarks at each hole location.
http://grundey.blogspot.com
"Allan Waterfall" wrote in message news:490d819a$1@bbsnotes.ugs.com...
> Help needed.
> yet to create one.
> Thanks
