Bolt hole circles
How do I draw a bolt hole circle and then place 5 or 6 holes spaced around the circle in the solid edge 2d version.
Re: Bolt hole circles
2 srep process  1.) create geometry, 2.) dimension & Annotate IE: show center marks
See video:  http://screencast.com/t/1cslJOA8iW
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
manual method... http://screencast.com/t/8GaRY24Ospq
Matt Johnson
Ally PLM Solutions
http://allyplm.com/
Thanks for the information, I don't understand why it does what it does , but I can now do bolt circles,  thanks.
