Boolean Operation
Builder
Builder
Hello Everybody,
I have Porous strcuture on the top of it, I have created Cube. The sole purpose is do to subtraction so that end product that is cube will left with empty pores in order to make geometry ready for CFD Analysis.
I try to perform it by following the feature< subtract. Unfortunately I result I am getting says unsuccessful.
Attached please see the pic of geometry. I am looking forward for any sort fo help.
Kind Regards
Varun
3 REPLIES 3
Re: Boolean Operation
without the files it's hard to guess what s happening,  but my assumption is that there is some non manifold area(s)
can you share both parts...
im sure that if you tried the same process with parts of my simple gemoety you will see that the comand works...
sometimes with geometry like this you need to make minor offsets either + or - to account for and work around non manifold areas..
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hello Varun:
I agree with @Johnson_BigMatt
There are some overlapping faces which will prevent a successful boolean subtract.
You figure those out or share the parts for inspection.
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
[ Everything under the Sun about - Solid Edge ]
there was a recent similar post that may offer some help for you.
please see https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Craters-of-the-Totem/m-p/374783/hig...
Matt Johnson
Teamcenter 10.1.7
