Borrowing license USE_SERVER License Found
Hi all,
I have problem related to floating license. When I try to borrow license Solid Edge, this box will prompt out.
The license file on the machine contains the USE_SERVER option. This option does not enable license borrowing. To enable borrowing contact your administrator and install the license file from the server on this machine.
Anyone can help?
ST9 Users
Re: Borrowing license USE_SERVER License Found
For license borrowing to work you must copy the SElicense.dat file from the server to the client machine that you want to borrow on.
Thank you @uk_dave
Anyway,
Do i need to edit the license file?
Or just copy it and paste onto the client pc?
No editing... simply copy and paste.  The license file on the client must match the license file on the server in order for borrowing to work.
Follow @uk_dave's suggestions! You have to use same license file on client and server, so you have to copy it from server. (I think you used "I know license server name" at setting license up. This makes a simpler license on client what doesn't support license borrowing).
BR,
Imics
