Breaking component associations after using mirror command
I may need to make a symetrical assembly inside another assembly but then may need to change the mirrored assembly afterwards without changing the original. At this time I am not sure this will be the case but I would like the option.
Is it possible?  How do I do this?
Dave
Re: Breaking component associations after using mirror command
Yes, you can do this RMB on mirrored assy and use Drop command! :smileywink:
BR,
Imics
