Build, Built Exclusively From ST8 Solid Edge Student Edition
This Build Took One Year And A Half To Build And Design Via. Solid Edge ST8 Student Edition
More Parts To Add For The Future
Very Grateful For The Use Of Solid Edge... Tech, Mentors.
Thank You
GregoryLee Crouse
GLC Overlook.JPGGLCoverlookGLC Overlook Underside.JPGGLCOverlook Underside
Re: Build, Built Exclusively From ST8 Solid Edge Student Edition
MLombard
Retired
Great Job! It's very interesting seeing where all of your questions on the forum were leading.  I'll bet the actual building was even more challenging than the drawing!  That's a lot of angled cuts. Anyway, great job, and thanks for sharing with us.
looks like a lot of work...  good job
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
What will it be used for?
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
