CGM to SE Draft
How are you opening CGM files in SE?
I know we can not natively...
DXF is the best intermediate...
Any client based tools you found helpful?
Right now I'm going CGM --> NX --> DXF --> SE...
Want to go CGM --> DXF --> SE  (Ideally SE will add CGM to import/open list of supported types)
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
4 REPLIES 4
Re: CGM to SE Draft
Matt,
Give Larson a call. They are CGM experts. I know them very well and I believe they can take care of you on this one.
Jason Newell
Solutions Architect
www.jasonnewell.net
Re: CGM to SE Draft
Hello @Johnson_BigMatt,
yes larson can be here the best option. Microstation can also open cgm files and save to dxf.
Most converter create with a cgm file only a embedded picture in the cad file format you wish.
In older times, it was possible to import cgm in some office product.
cgm you can view with insight connect to but saving here seams not possible.
Best Regards
Wolfgang
Re: CGM to SE Draft
@Johnson_BigMatt  Here is a cloud based site that supposedly will do this and also has a free plan if not doing too many/big files...
https://cloudconvert.com/cgm-to-dxf
http://Grundey.blogspot.com
Re: CGM to SE Draft
@KennyG
Yea, I've seen a few online converters,  I'm not a liberty to trust such sites with our data.
Matt Johnson
Teamcenter 10.1.7
