Calculating Weight
I was wondering if Solid Edge has a video on how to calculate weight, Volume, of a part. I looked in Help does have it in text not on YouTube.
Greg
Hi Greg,   You first need to apply a material type to the...
Hi Greg,
You first need to apply a material type to the model[s]...
Then go to the "Inspect" tab and select "Properties" > "Update"....
Testing: Solid Edge 2019
