Callout properties checkbox reverts
Hey.  I attached a pic of the checkbox that I want NOT to be checked.  When I go back to the general tab and save the callout settings to a certain name and retry, the checkbox always checks again while making a bend table callout.  Any ideas.
Re: Callout properties checkbox reverts
Esteemed Contributor
Hi Jeff,
Unfortunately the callout properties seem to draw from the last used configuration....the same with the additional control buttons. This could also be related to how your "template" file is set.
The saved setting only caters for the callout text used....though, it ought to respect the supplimentary settings being applied to it.
This seems like a great Ehancement Request summision to your VAR....I'd support it.
Solid Edge ST10 [MP5] Classic [x2 seats]
