Betreff: Callout properties
@bshand IIRC whatever you have set first for override is what is first taken but then changing the override later and redeploying is then not taken without first resetting the user registry.
If making changes to seadmin after initial deployment, the best practice is to remove the user registry first before redeploying.
Either way, seamdin never gives you what you need or expect ;-)
@uk_dave That doesn't concur with my experience.
Bruce Shand
