Can I change how smart quantity is called out?
Due to company standards, I'm trying to figure out if I can change how smart quantity is displayed. Instead of say 9 X when there are 9 holes, can I make it read like 9 PLCS, as per company standards?
I was able to change it in a callout, but it reverts back to using an X, and I can't figure out if I can change it to default to PLCS, can't seem to change it at all using a smart dimension.
EDIT: NEVERMIND, I FIGURED IT OUT.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Re: Can I change how smart quantity is called out?
@nominus38, Please share. I was wondering how to make %QN not spit out an X automagically.
Bruce Shand
You have to go into your styles and change it there. Dimension styles.
Solid Edge 2019
I see now. Confusing. I don't know why "smart depth" is separated from "feature callout". And why are %QC, %QA, and %QN pretty much the same except that %QN is "smart" in that it is blank if there is only one hole. Is this explained somewhere in help docs?
Bruce Shand
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uid:index_newse:xid459404:xid1151068
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uid:index_annotations:xid280274:symtxt1...
These are all I can find now. I did find some other stuff, no idea where it was now.
Solid Edge 2019
Oh, and here
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uid:index_annotations:xid280272:xid2802...
Solid Edge 2019
Thanks for the links
Bruce Shand
