Can I print a A0 drafting on a A3 paper
N/A
Hi All,
I am using the free Solid Edge 2D drafting, just wonder if it is possible to print
a A0 drawing onto one or multi A3 papers? If yes, how could I set it up?
I have played around the Sheet Setup and tried with printer setup, it's no use.
Any advises would be appreciated.
Re: Can I print a A0 drafting on a A3 paper
N/A
Jiwei,
If you are wanting to break a drawing into multiple prints, the best way is
to use print area for each segment.
Rick B.
