Can JT files be used to publish to web sites for hosting/viewing solid edge assemblies
Builder
Builder
Edgers we have need to post solid edge models to external web site due to strict sercurity requirments and I was woundering if any one has attempted this before.
I'm aware of web publisher but we really only wanted to display main areas of our plant which we can do using jt format of what we want them to see.
So my immediate thought was how to publish JT files to be compatible in common web browsers and even if its possible using JT or perhaps another possible web format like vrml?   I know I can save to both formats from SE but do you need a browser plug- in for it to work?
Just curious of how others have tried this and the best light weight web format to utilize and publish?
Cheers
Phil
ST9
WIN 7Pro 64bit
DELL T5810 3.7-4Ghz 32Gb ECC
5 REPLIES 5
Re: Can JT files be used to publish to web sites for hosting/viewing solid edge assemblies
Hi @mspadmin
Recommend you use (scheduled) scripts to automatically publish JT models to a dropbox folder. As you know dropbox is an awesome solution to securely and efficiently share data with others. You can include the JT2Go software as part of the JT model share. Thereby your vendor, client, site, etc. have a single source for the JT viewer installation software and very lightweight monolithic 3D model. Stick to JT2Go, it is an awesome lightweight viewing format, and use the latest 11.2.2 feature rich version. I cannot think of anything better, simpler and more compact than this. Maybe someone else will have an alternative suggestions to consider.
Builder
Builder
Yer Pieter
Agreed dropbox and JT2Go was my 1st choice but they wanted to take extra security measures that prevents those accessing the documents from copying/downloading or even recording screen which is a bit extreme.  So an external hosting of the data was suggested were the 3D content is viewed only and not downloaded in anyway.
I think dropbox can provide this type of security?
ST9
WIN 7Pro 64bit
Have you ever seen Web publisher module? It makes a web browser ready dataset from your assy... One of our customer has built an own webpage with their product by used WP.
One of my friend recorded this video:
I suggest taking a look!
BR,
Imics
Builder
Builder
Thx Imics
Does look useful but looking to host JT files but not sure if these files are web formatted or need special add in to web browsers for viewing them on line??
cheers
Phil
ST9
WIN 7Pro 64bit
I think you will find the solution here!
Stefan
smitsch@unitec.de
www.all4edge.de
