Re: Can You Bend Mesh/Screen in SE ST9
Alex,
Looks like the mesh you are using is pretty unique - I did some reasearch on this stuff.  I went to www.bwire.com - and they explain that the mesh you are using is called "Welded Wire Mesh" as opposed to "Woven Wire Mesh"
This makes all the difference in the world for you - the woven is what most people will be thinking of when they hear about wire mesh - - -
I think the swept extrusion that you are using came out pretty good - I have been in contact with some people I know on a similar project - and we ended up using the swept extrusion after much back and forth.
