Can not modify sketch
Please help me how to modify the sketch.
I am create a sketch and I want to modify it (Modify style, color and width) but the dialog box with edit command does not work.
Betreff: Can not modify sketch
Hi @4Ctech
suppose You have turned on the "Relationship Colors"
So go to the Inspect tab and turn it off.
Pretty cinfident that afterwards You will be able to change the line settings
Wolfgang
It worked, thank you so much!
