Can startup time be reduced?
Not applicable
I like Solid Edge 2D, but the long startup time is an issue since I
typically do a bunch of small projects or need to do a quick mod to an
existing file.
What is Solid Edge doing during this startup phase (loading libraries,
checking for updates??), is it possible to change the configuration so some
of the startup tasks are reduced or eliminated?
Paul T.
