Can't access tutorials
Not applicable
Hello all,
Just started using Solid Edge -- I'm having troubles getting the tutorials to load.
I can get to the page where the 3 tutorials are listed, I can move the cursor over
the names and get the intro page for each popping up on the right. But when I click
on the tutorial, nothing happens. Is there something I'm missing here? Thanks for
any help.
Re: Can't access tutorials
Not applicable
Mr Gillis,
Have you at any time installed Solid Works on your system?
There is a known clash that affects the Solid Edge tutorials. I can send a
simple fix to resolve the clash. It will not affect your Solid Works
installation.
Rick B.
Not applicable
"Ricky Black" wrote:
>Mr Gillis,
>installation.
>Regards,
>Rick B.
I have solidworks on my system and have an similar problem. Could you post the
fix please.
Not applicable
>Mr Gillis,
>installation.
>Regards,
>Rick B.
fix please.
Not applicable
I have attached a zip file that has a file 'menu.exe' within it. Extract
this file 'menu.ext' into the '\Solid Edge 2D Drafting\Program' folder.
There should be a file there of the same name. Let it replace the file.
I originally thought this was an executable that was run separately to fix
up the software. It is not. It is run by 2D Drafting to display the
tutorials.
After dropping in this executable, run 2D Drafting again. Let me know if it
does not fix the problem.
Rick B.
Not applicable
>tutorials.
>Regards,
>Rick B.
Thank you.
I joined this group just because I had the same problem. The "menu" download fixed
it.
Tom
