Can't active Solid Edge ST10 from new license File and old dongle.
Hi Everyone.
Siemens was sented to me a new license file of solid edge ST10 and the link download it.
i was install it, but when activation i has problem, it has warning wrong license. so, i need to have new dongle for new license or not?. this dongle for license ST9.
Please help me. Thank so much !
Re: Can't active Solid Edge ST10 from new license File and old dongle.
You have to update the license file on the license server as well.
Probably you need to restart the license service as well (with lmtools.exe perform: stop license service, reread license file, start license service)
I'm not sure but it could be that you also need to update the license server from ST9 to ST10, have a look in the ST10 downloaded archive at: ...\Solid Edge ST10\DVD\License Manager
... and don't forget to update the nameserver or server ip in the new license file.
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
For ST10 floating licenses you *must* also upgrade your license server FlexLM version.  You cannot simply drop your ST10 license file into an existing ST9 Flex setup.
This problem was solved. Thank so much, you guys ^^
