Can't edit drawings
Good Afternoon From this morning I can open all my drawings but I can't edit them. I re-installed Solid Edge 10 2D with service pack 3, still the same. Can anyone help please? Thanks Hendrik Smit
8 REPLIES 8
Re: Can't edit drawings
Hello @HendrikS
What kind of edits are you trying to make ?
Can you give more details on what are you not able to do.
~Tushar
Hi Tushar
Any geometry line, circle,hatch etc.
I can't change the diameter of a circle, hatch or layer.
I can create new geometry and edit it, but anyrhing I did the previous day is a no go.
HendrikS
Hi @HendrikS
can You select those items and not change them or is also selecting not possible?
Wolfgang
HI @HendrikS
can You upload an example file?
Wolfgang
Hi Wolfgang
Can't select them either.
HendrikS
Hi Wolfgang
Found the problem, in the select options, Active layer only was turned on.
I think I must kick myself, did not know the setting is active even if you open another drawing.
HendrikS
Bravo @HendrikS
You can mark your own reply as a solution so it becomes easy in the future for other users to find.
Hi @HendrikS
this is exactly what I assumed to be the reason.
I have seen this that many times, that - of what reason ever - this option was changed to Active Layer only.
I can imagine that is also has happened without interactive input by the user.
Maybe there is a hidden shortcut, a mouse clicking sentence or what ever.
As I sayed, this has been seen for a long time for different versions of SE and with many, many different users.
I believe that it was not Your fault.
Wolfgang
