Can't get 2D drafting to install
Not applicable
I have downloaded Solid Edge 2D Drafting V19 from the web. When I try to install
the file the Installshield Wizard gets to the extracting files page and this message
pops up. ( The contents of this file cannot be unpacked. The executable you are
attempting to run has been
corrupted. Please obtain another copy of the file, verify its integrity, and try
again.) When I press the OK button the installation stops. Can someone help? Thanks,
Fred
Re: Can't get 2D drafting to install
Not applicable
Have you done what the message suggested (download another copy)? Your
download may very well have been corrupted or may be incomplete.
http://grundey.blogspot.com
"Fred Aemmer" wrote in message
news:459d5b77$1@bbsnotes.ugs.com...
> install
> this message
> you are
> and try
> help? Thanks,
> Fred
Not applicable
>Ken
I have downloaded the file four times with all firewall and virus programs turned
off but I always get the same notice.
>> install
>> this message
>> you are
>> and try
>> help? Thanks,
>> Fred
Not applicable
Fred,
Did you ever get the software to install properly? If you did not, Please
email your mailing address to me and I can have someone send a CD to you.
Rick B.
Not applicable
I have similar problem to install the 2d drafting software. I had downloaded Solid Edge 2D Drafting from the web serveral times and alway not successful in getting it install. When I try to install the Installshield Wizard gets to the extracting files page and this message
attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again.) I did what it told and re-download the file again but still face the same issue.
Please help.
Daryl
Not applicable
Daryl,
How recently did you download the software?
Do you still have the executable on your system?
If you do, right mouse click on the executable and click on Properties.
In the file properties dialog there should be a "Digital Signatures" tab.
Click on that tab and tell me what the date in on the first line in the
"Signature list" field.
If you do not see a Digital Signature tab, then the file is becoming corrupt
during download.
What is your connection speed?
How long does it take to download the executable?
Rick B.
