Can't get chamfer to work
I have problems getting chamfer to work.
Trying to place a 2mm. x 15° chamfer, but it wont allow be to select the edge.
3 REPLIES 3
Re: Can't get chamfer to work
Could you please try the same with a new simple extruded circle and confirm the same problem?
Yasser
Did you try to use "face" option instead of chain?  It should be working...
BR,
Imics
Worked with chain.
I uploaded a small video, just in case others got the same problem Smiley Happy
