Can't make ST4 work
N/A
I downloaded ST 4 on my computer at school, but it won't work. This happens when I try to run it:
"Solid edge license check. The feature solidedgeacademic failed to check out for the following reason: System clock has been set back. Feature: solidedgeacademic License path:C:\Program Files (x86)\Solid Edge ST4\Program\SELicense.dat; FLEXnet Licensing error:-88,309 For further information, refer to the FLEXnet Licensing documentation, available at"www.flexerasoftware.com". "
"Solid Edge License Check. You do not have any valid Soldi Edge licenses. Contact your system administrator to obtain a license."
Nobody at the University have been able to help me. I've tried to register again, but I haven't received a new email with download link and license file.
Please help!
Re: Can't make ST4 work
Method one:
Save the license.txt file somewere on your pc, and rename the file and
extention to SElicense.dat than copy this file into C:\Program Files\Solid
Edge ST4\Program overwriting the existing one.
Or
Open the existing SElicense.dat file in folder C:\Program Files\Solid Edge
ST5\Program\ with notepad remove all text, and paste the text from the
licence file that was send to you in this file and save it.
Or store the created SElicense.dat somewere on your PC and use the licence
utility located under licensing in Solid edge, point it to this file.
Succes,
Jan Bos
The Netherlands
"se.sether@stud.uis.no"
wrote in message
news:se.setherstud.uis.no.5kkmgo@noreply.bbs.industrysoftware.automation.siemens.com...
> and license file.
> Please help!
> se.sether@stud.uis.no's Profile:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=462318
> View this thread:
> https://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=50443
