Can't modify dimension value
I'm open simple sketch and put dimension then modify dimension dialog can't show. please see in attach file.
  • this is standard user when switch to adminstrator is working normaly
  • I'm change "C:\Program Files\Solid Edge ST9" to full control
(view in My Videos)
Re: Can't modify dimension value
The reason you can't change the dim values is because your Maintain Relationships setting is turned OFF.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
