Can't put dimension align reference edge
Hi all;
I have some case want to put dimension with edge and hole. It not align. We have solution to fix it?
- Solid Edge ST10 MP00
- 12.rar is video file
3 REPLIES 3
Betreff: Can't put dimension align reference edge
Hi @Famer
simply change to Dimension Axis instead of 2 Points method.
See video:
(view in My Videos)
Wolfgang
Re: Can't put dimension align reference edge
Edit: I now see Hawcads previous answer...
Famer,
if I understand correctly you want to place the dimensions aligned with the part edges?
Then you select 'smart dimension' + set 'dimension axis'. Then select two points on the edge (it's indicated by a dashed line) and after this place the dimensions.
Siemens EMEA GTAC Support
Wow Wow Perfect!!
Thank you.
