Can we use the “initials” for callout used in TITLE BLOCK for DRN BY sign./initials. Refer below ima
Can we use the “initials” for callout used in TITLE BLOCK for DRN BY sign./initials. in ST10
12 REPLIES 12
Re: Can we use the “initials” for callout used in TITLE BLOCK for DRN BY sign./initials. Refer below
Not sure what you're asking.  If you're using file properties from a part file to populate your title block, you're kind of limited to what you can do.  If you take some time and create custom properties in your template part file with the properties manager, you can then populate your title blocks with special callouts of anything you want.
Matt
Hi @MattS
no, I believe that what @Somnath_Pore is asking for is a very old issue.
You can define certain user informations from within options dialog.
One of them is the user initials.
The sad story is, that all those over 20 years using SE, where this info field was available, I never ever have seen any way/method to get it out with on board functions.
So again this is a very good idea, over 20 years old, but nobody has gone this way to a lucky end.
Wolfgang
@hawcad master ER# 1714708...
Hi @uk_dave
thanks for sharing that info!
Let's hang on!
Wolfgang
Re: Can we use the "initials" for callout used in TITLE BLOCK for DRN BY sign./initials. Refer below
Can you please explain with any example?
So I can try at my side.
Feel free to call on us, if in doubt.
Somnath Pore
Regd. Off.:-A9/6, suncity, sinhagad road,
Pune, Maharashtra, India- 411051
Ph.:-(+91) 7588330580, 8766813626
Works:- Srv. No.:- 26/9,
Near Deccan Honda Service center.
Narhe,
Pune, Maharashtra, India- 411041
Hi @Somnath_Pore
What exactly to You mean where an example should be provided?
Wolfgang
You can create a custom property called DRNby in the Draft File Properties, set the value of the property to your user's initials, then access the custom property with a callout accessing %{DRNby}
We had to go this route when there was an issue a lot of versions ago when a revised file overwrote the Author property from the original creator to the person making the revision. We swapped out using the Author property for a custom Drafter property and never went back.
Dale Smith
Mitsubishi Electric Power Products, Inc.
ST10 MP7 - Insight
Thank You Sir.!!
Sorry..
I have replied to wrong... it was related to other query.
Somnath
