Cannot delete synchronous feature
Hi Community,
I am having trouble great trouble deleting features in synchronous, I keep receiving error mssgs such as the one in the attached JPG. I have tried different ways to eliminate the error mssg but to no avail.
If you know the solution to this problem please post a response.
Thanks in advance
Re: Cannot delete synchronous feature
try selecting your inside surface also
MLombard
Retired
If you select the feature from the PathFinder, you'll see that the flat surface at the bottom of the slot is also selected. You can delete it that way instead of just selecting from the graphics window. TBD's suggestion is also correct. You have to think of how the remaining faces will continue to form a solid. The only way is to get rid of all the faces of the feature.
