Cannot find the Parts Library
N/A
I installed Solid Edge, and I am going through the modeling tutorials, and realized that I cannot find the Parts Library tab that is supposed to be on the left side of the page. Any ideas...please advise.
Steve
Re: Cannot find the Parts Library
Some Questions: are you in the assembly enviroment? if yes then the parts library is switched off. To switch it on try the following:
take one of the icons and see that in the flyout there is located in the top a black triange with a line underneath. if you click on that you can see the parts library switched of. if you switch that on you will get it.
good luck.
Donald
