Carriage return symbol when editing dimension subfixes
A few versions ago, when a carriage return (ctrl+enter) was placed in a subfix, a vertical line appeared letting you know a carriage return existed.  This line is no longer there and it makes adding multiple lines in a subfix much harder to edit later. I know there are two subfixes but I prefer to enter multiple lines all in one subfix.  This issue has been discussed before.  I'm not sure whey the carriage return line was removed, but I strongly believe it should be restored.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
5 REPLIES 5
Re: Carriage return symbol when editing dimension subfixes
i 2nd that
PLM World Member Genius PLM World Member Genius
It works with Shift+Enter.
I meant shift+enter in my original post.  I do shift+enter but the carriage return symbol would help show this more clearly.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
How about %RT ?
LMGi
www.TLMGi.com
Jason,
That works, but the shift+enter was a little quicker and just showed a little vertical line at each carriage return.
I wonder why it was ever take out?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
