Center distances
Hi There,
I try to take a distance from center to center but Solid Edge does not give me the attachment points of the center. Anyone know if this is a known problem or if there is way to fix this?
Thx
Alex
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
Re: Center distances
It appears that the edges you are selecting are not arcs or circles, but curves. Try using the Inquire element tool to select those, and see what type of element they are. The Optimize command might help you clean up imported geometry.
HTH,
Jason
Thank you Jinglis for your quick reply,
I can assure you that it really is a perfect circle. For a better understanding, I masked some parts. I show you here from two perfectly round tubes.
Alex
(view in My Videos)
Video is not working anymore...
They may look like perfect circles, but if the models were created in some other CAD, and translated, they may be represented by curves instead of actual arcs and circles. The Inquire Element tool will tell you if they are curves or circles.
Jason
These elbows are from our database and created by us probably in SE vs14 or 15.
The problem is general. With every round parts, not just these elbows.
It's a new issue since the installation of ST7. I did not have this problem in ST5.
Hmmm. In your first video, it was highlighting sections of the arc, not the full circle, and wasn't showing the correct glyph. I tested this in ST6, and it worked as I expected. I just tried it again on my test machine with ST7, and had a result similar to yours. Try using the measure minimum distance command with it set to keypoints. This worked as expected in ST7.
Jason
Esteemed Contributor
Try changing the selection filter from "All Elements" to "Keypoints".
Production: ST9 MP10
Testing: ST10 MP3
Work fine with Keypoint instead of All Elements.
Thank you Grundey.
Thank you guys for your time.
Alex
In ST6 I had it set to All elements. With the same setting in ST7, the result is different. Is this a WAD, or a regression?
