Center of Mass symbol color
I would like to ask you why the symbol of center of mass is changing the color from green to red ?
what does it mean ?
thank you,
Arek
Solid Edge ST8 MP10
5 REPLIES 5
Re: Center of Mass symbol color
Do you have center of volume turned on?
Bruce Shand
no, center of volume is off.
Solid Edge ST8 MP10
Maybe an update in the physical properties dialog is needed?
Edit: when that needs updating it appears magenta on my machine.
Bruce Shand
Thank you very much.
Arek
Solid Edge ST8 MP10
That's correct. It changes color to let you know it is no longer up to date.
