Center-plane command in the capture fit dialog box
Hi guys,
can anyone confirm me that it's impossible to capture the reltions of center-plane command when I placing a part in assembly? I'm asking this because the  SEhelp don't specify which relations are admitted.
Thank you in advance
Re: Center-plane command in the capture fit dialog box
  • The Capture Fit command cannot capture angular, cam or center-plane relationships.
