Centre of gravity
N/A
Hello
I am using Solid Edge ST4
I would like to know where can I show the centre of gravity of my parts.
Can I only do it in the draft environment or can I show it in the part or assembly environment also?
Waiting for your replies
All the best
Re: Centre of gravity
N/A
In Assembly or Part go to the "Inspect" Tab and then click "MV
Properties". A Dialog box will open and allow you to check "display symbol"
Of course you need to have each parts Material properties properly set.
If not Click on Properties Manager to the right of MV and fill out the
Assembly and Parts materials.
Bob
On 2/12/2012 Sunday 1:47 PM, ottsutt@hotmail.com wrote:
> Hello
> parts.
> All the best
N/A
The Properties Manager is only available in Assemblies. Sorry if I
confused you.... I was working from memory.
> symbol"
> set. If not Click on Properties Manager to the right of MV and fill
> out the Assembly and Parts materials.
> Bob
>> Hello
>> parts.
>> All the best
N/A
Hello
Thanks a lot, i was looking for this.
Thanks for the reply
