Change Author
Hello!
So I got a computer that someone else used before me. When I got the computer I installed Solid Edge ST8 and changed the User Profile there. After this I also changed the Windows User ID but still it´s not my User ID that is shown when I start a new part of draft.
Is there any way to change this?
Best Regards Gustav
Re: Change Author
In system properties click on network id then click "next" on the following screens until you get to this screen: (I'm not sure this is it but give it a shot. Probably not since I would think this is assigned on log-in)
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
Re: Change Author
This is how you do
http://social.technet.microsoft.com/wiki/contents/articles/19834.how-to-rename-a-windows-7-user-acco...
after doing that, youll have to delete the solidedge registry
BUT WARNING THIS ERASE ALL SOLIDEDGE PREFERENCES
