Change Offset default from Chain to Single?
N/A
Hi, when I'm drawing in non-parametric mode I often draw a line then offset
it a specific amount. The default setting for Offset is Chain, but most
times I want the Single offset. Is there a setting in SE2D to change the
default to Single from Chain? Thanks, Rick
Re: Change Offset default from Chain to Single?
N/A
No but you can change the selection by hitting "S" on the keyboard.
David
"Rick Clise" wrote in message
news:489b0614@bbsnotes.ugs.com...
> offset it a specific amount. The default setting for Offset is Chain, but
> most times I want the Single offset. Is there a setting in SE2D to change
> the default to Single from Chain? Thanks, Rick
N/A
Thanks David
"David Rieschick" wrote in message
news:489b6d79$1@bbsnotes.ugs.com...
> David
