Change default bend equation?
Builder
Builder
How does one change the default bend equation from .33 to .333 its a pain to do this by hand everytime I create a new sheet metal part.
Re: Change default bend equation?
you have to change this value in the Template file of the sheet metal, and it will work.
Yasser
Honored Contributor
Honored Contributor
You could also start using the gage file XLS file and use that as your default.
