Change faces colours in draft
Hello Experts,
I could find it in styles. Is it possible to change part faces colours only in draft view, I mean w/o 3d model ingeration.
Thank you.
CB
Re: Change faces colours in draft
Like using the Fill command with a Solid Color - is that what you are thinking of:
~Tushar
Tushar, you are the best. Thanks.
