Change location of Simulation Express output html file
Is there a way to change the output path of the html file generated by Simulation Express?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Re: Change location of Simulation Express output html file
Anyone?
Kyle Joiner
IPA LLC
ST10 MP1
chirp, chirp...   chirp, chirp
I've tried digging deep in registry, but it seems this is coded (temp directory) in dll... Smiley Sad
Anybody?
BR,
Imics
The issue I have is that it is buried deep in the users folder under app data and these folders are kept hidden as part of our company IT policy.  It would be nice to have the report generated as a PDF or some other format that can be saved to a folder of choice.
The current path is:
file:///C:/Users/username/AppData/Local/Temp/ysis2%20-%20Imported%20Parasolid/ysis2%20-%20Imported%20Parasolid_Stress_1/ysis2%20-%20Imported%20Parasolid_Stress_1.htm
Not too user friendly.  The "parasolid" name is due to my "workaround" to try to analyse a sheet metal part with some cross ribs in simulation express.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
