Change material color using variable table
Can we change material color using variable table?
I have been using NX9. There was an option for changing material color through variable table. I cant find that kind of option in solid edge.
Is there any other option to do the same?
Re: Change material color using variable table
You cannot change part color using the Variable Table.  This can only be done manually or through automation (VB, C++, etc...).
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
