Change property callout -- change date format
Hi
Anyone know how to change a property callout ??
I want to show date as YYYY.MM.DD     Not DD.MM.YYYY
The callout i want to change is  %{Modified}
Re: Change property callout -- change date format
Hi WJ,
You can find help on date and time formating at:
http://support.industrysoftware.automation.siemens.com/training/se/107/en_US/index.html#uid:index_an...Smiley Tongue
I'm suggesting the following code to get what you want
%{Modified/@yyyy.MM.dd}
If you want months in letter instead of number, type MMM.
If you also want months to be all capital letter, you can use the following example and modify it as per your need:
%{Modified/@dd-MMM-yyyy/TC1}
See help on "Format codes to modify reference and property text output"
Michel
Works fine ,, Thanks Smiley Wink
